On board air compressor LR3
Old Feb 10, 2014 | 01:47 PM
EAS's Avatar
EAS
Default On board air compressor LR3
I would like to upgrade my 2005 LR3 HSE with an on board air compressor capable of airing tires and operating a jack and an air wrench for tire removal and installation.
Can anyone recommend a brand and model of air compressor and comment on the location of your installation?
Thank you.
Old Feb 10, 2014 | 02:05 PM
houm_wa's Avatar
Do you have rear Climate Control?
Old Feb 10, 2014 | 02:37 PM
EAS's Avatar
EAS
Yes, our LR3 has rear climate control (and 3rd row seating). For a ham radio antenna installation we had to go to our 3rd choice location (near the fuel filler). These LR3s are packed. That is why I am seeking experienced advice.
Old Feb 10, 2014 | 05:43 PM
houm_wa's Avatar
Yeah...sorry. I have an air compressor mounted in the little cubby on the driver's side in the boot. I believe if you have 2nd row CC there are some refrigerant lines that go through there or something....I have a 5 seater with no rear CC.
Old Feb 10, 2014 | 05:59 PM
EAS's Avatar
EAS
Alas. I appreciate your help. I was hopeful that one of the Warn winch/compressor combinations would fit into the ARB LR3 bumper, but no such luck, so I am looking at other on board air options. Hopefully someone has a solution for a 7-passenger LR3 HSE with the rear climate control.
Old Feb 10, 2014 | 09:26 PM
Mack73's Avatar
Do you have a 2nd battery? Plenty of room on the driver's side in the engine compartment to mount one.
Old Feb 10, 2014 | 10:32 PM
EAS's Avatar
EAS
I do not have a second battery. I will check that out in the daylight. Thanks for the suggestion.
Old Feb 11, 2014 | 02:57 PM
houm_wa's Avatar
...great idea, Mack. EAS you'll be happy. Easy wire run too!
Old Feb 11, 2014 | 04:52 PM
unseenone's Avatar
If he's got / adding a winch he might want a 2nd battery though. I just throw a Viar in the boot when I need it compressor. I ran two power runs to the back with hookups, for the Ham, compressor, fridge, etc. Just kicking out more ideas..
Pics here.. DISCO3.CO.UK Photo Gallery - Home > Member Galleries > tlt
Old Feb 11, 2014 | 09:46 PM
EAS's Avatar
EAS
I did not see enough room for the VIAIR tank, only for the compressor. The tank seems to be the problem.
