Bought an 05 with 220k miles - Need help
Old Jun 7, 2023 | 10:41 PM
DakotaTravler's Avatar
I recommend whatever works, but I went OEM/Delphi, they are only $13 each. So a little over $100/set. Helps to shop around!
Old Jun 7, 2023 | 10:53 PM
MyChocolates's Avatar
Nice. Got your message. Ordered =)
Old Jun 8, 2023 | 01:05 PM
Gordo51's Avatar
Originally Posted by MyChocolates
That’s for sure, kinda want to leave it for fun.
I used liqui moly high performance atf
People recommended Mercon SP but I found Liquid Moly on sale at Germanparts.ca for $200 for 20 litres so bought that. Plan to drain/fil/drain the Trans several times to get out most if the old stuff. In my opinion it is not worth the expense and hassle of changing the filter. As someone else commented, that filter will only plug up if your Trans breaks apart.
Old Jun 8, 2023 | 10:39 PM
I already replaced oil pan, i found out the tranny is leaking from the electrical plug as well.
I have already replaced all of that. Today i took it to the exhaust shop, hopefully will be fixed tomorrow.
Anyways, i bought the solenoids so i gotta bring the valve body down anyways, i will replace plug as well as that little plastic square seal on the top of the valve body.
Old Jun 8, 2023 | 11:15 PM
There is more than one seal above the valve body, I think three in total. The others being basically round tubes.
Old Jun 9, 2023 | 11:55 AM
tracyc's Avatar
Yeah, make sure to do the round sleeves and the foam seal too when you're in there. There are kits available with Zf parts that have everything you need.
Old Jun 9, 2023 | 11:57 AM
what is the foam seal?
I am learning soo much you guys are the best.
Old Jun 9, 2023 | 12:44 PM
tracyc's Avatar
It'll come up if you search for something like "zfhp26 foam protection strip". Here's one from fcpeuro, but please confirm it's the right one before ordering:
https://www.fcpeuro.com/products/sol...-zf-1068327241
Old Jun 9, 2023 | 04:35 PM
P-Bod's Avatar
Yep, that's the correct foam strip from FCP.
My solenoid kit from TheCTSC.com came with a foam strip, but they also sell one separate. We have 7 solenoids.
Protection Foam Strip (thectsc.com)
This is a good seal kit too:
Sealing sleeve and adapter kit 6HP26/28/32 (thectsc.com)
Old Jun 9, 2023 | 06:37 PM
Okay ordered the foam thingy.
also, is this Oem? Something missing here?
