Broken grill tabs
Old Mar 17, 2023 | 08:46 AM
lenzda's Avatar
Default Broken grill tabs
Self explanatory, any good remedies? The grill stays on, just not very secure.
learned my lesson not to take the grill off in 20degree temps
Old Mar 17, 2023 | 03:32 PM
houm_wa's Avatar
You can prolly find a replacement grill at Roverland Parts.
Old Mar 17, 2023 | 03:52 PM
DakotaTravler's Avatar
I think I am down to one left..... tab that is. I was thinking of getting some thin metal banding - like on the back of a garage door opener remote (sorry, only thing I could think of). Then rivet or plastic weld them on. I also though of velcro, but it can be a pain.... I just don't want to spend $$ for a new grille.
Old Mar 18, 2023 | 07:55 AM
lenzda's Avatar
Agreed, don’t want to spend money on a new grill. Velcro is a pretty good idea.
Old Mar 18, 2023 | 08:09 AM
SENC's Avatar
cable ties work just fine
Old Mar 18, 2023 | 08:40 AM
P-Bod's Avatar
I did this for the top. Couldn’t think of any good ideas for the lower tabs, but just the uppers holds the grill just fine.
Old Mar 18, 2023 | 10:44 AM
Blackngold77's Avatar
I feel like neoprene would work well, get compression for a tight fit and it'll grip. Cut squares of it and glue it to the bit remaining on the grill or put it in the hole.
You can get a roll of neoprene strip cheap on Amazon for like $5
Old Mar 18, 2023 | 11:00 AM
lenzda's Avatar
If I’m looking at your photo correctly, did you drill holes and use the omnipresent Land Rover plastic fasteners?
Old Mar 18, 2023 | 12:58 PM
P-Bod's Avatar
Exactly. I keep a bag of these around. QMET 10 mm 40 pcs/pack Push-Type...
Amazon Amazon
Old Mar 18, 2023 | 02:39 PM
P-Bod's Avatar
Sorry that link is bad. These are like what I use on a lot of cars. Rexka 25pcs Grille Push Pin Retainer Clips Fasteners Rivet 6503598 Compatible with 2007-2020 Jeep Wrangler & 05-10 Grand Cherokee WK https://a.co/d/1hKoh8W
If you go this route, check behind where you’re going to drill. There are braces to one side you’ll want to steer clear of.
