A/C problem
Old Jun 14, 2022 | 08:18 AM
  #31
VinnyAllenMX's Avatar
Originally Posted by Robert Saunders
to give some closure to my question .. in the end it was just the compressor control valve. The AC has been fine ever since.
Thanks for the update Robert. After I posted and doing some more digging I found a service bulletin that I believe was a result of the valve you're talking about. The compressor control valve you're referring to is the same as the direct pressure sensing valve (DPS) in this service bulletin and is mounted in the compressor, right? I think a new compressor may be in order given you have to remove the compressor to get to the valve anyway. https://static.nhtsa.gov/odi/tsbs/20...06303-9340.pdf
Old Jun 14, 2022 | 09:27 AM
  #32
Robert Saunders's Avatar
5th Gear
I'm was told by the gent who replaced mine, "yes the solenoid or direct pressure sensing valve is a common fault where L.P. runs too high and the H.P. runs too low thus insufficient pressure and consequentially heat is generated for sufficient energy transfer. Replacing the valve usually resolves the issue."
cheers
GBR.R
Aug 16, 2020 07:29 AM
knightmetro
Jul 19, 2018 09:27 AM
thorgal
Jun 8, 2018 08:21 PM
DieHard
Jul 14, 2017 09:19 AM
