Cannot remove the camber adjusting bolt on rear control arm
Old Apr 18, 2025 | 02:50 PM
Gordo51's Avatar
Default Cannot remove the camber adjusting bolt on rear control arm
I need to replace my rear upper control arms in my 08 LR3. I have the driver's side arm out. On the passengers side the camber adjusting bolt is seized in the ball joint at the knuckle. No amount of pounding with a big hammer has gotten it to move. We cut away the arm so nothing is in the way.
Any ideas on how to get his out without complete disassembly and pressing it out? Thanks
Old Apr 20, 2025 | 07:53 PM
lenzda's Avatar
Is the nut seized on the bolt or the bolt seized to the knuckle?
Old Apr 21, 2025 | 06:30 AM
enovak's Avatar
I had to cut the bolt and then use a punch to knock the remaining bolt piece out.
Old Apr 21, 2025 | 07:54 AM
x81's Avatar
x81
7th Gear
I had to cut the bolt and press out the bushing as the bolt had seized to it.
I used a ball joint press to do it on car without completely removing the knuckle.
Old Apr 21, 2025 | 03:54 PM
gmtech's Avatar
first air hammer and wd 40 or the sort. next. torch... cant be stuck if its liquid metal...
Old Apr 23, 2025 | 03:54 AM
loanrangie's Avatar
Reciprocating saw between the bush and the chassis bracket and cut it out.
Old Apr 23, 2025 | 10:34 AM
Gordo51's Avatar
This is not the Bush at the chassis bracket. This is at the top ball joint on the knuckle which carries the wheel bearing. We did have to cut the bolt at the center bushing on both sides.
Anyhow, we did get the camber adjusting bolt out. We used a pickle fork on the bolt head side to put tension on the bolt and then my brother hit the bolt with a large hammer while I pushed a 24 pound chunk of steel against the knuckle to minimize its movement. The bolt was amazingly rusty.
Old Apr 23, 2025 | 07:18 PM
loanrangie's Avatar
Ah i missed the camber bit.
Old Apr 25, 2025 | 01:00 PM
enovak's Avatar
you may have to use the pickle fork on the ball joint except it will destroy the ball joint so you will need to put a new one on it. Howevr, you may need a ball joint on that control arm anyway
Old May 14, 2025 | 12:54 PM
carputech's Avatar
3rd Gear
Any ideas on how to get his out without complete disassembly calcular finiquito and pressing it out? Thanks
Start by applying a generous amount of penetrating oil (such as PB Blaster or WD-40) to the bolt and allow it to soak for at least 15-30 minutes. If the bolt remains stuck, try using a breaker bar or an impact wrench for additional leverage.
