Can't get out of park and limited gears available
Old Aug 15, 2023 | 12:11 PM
Charron's Avatar
Default Can't get out of park and limited gears available
What would cause the shifter to not be able to get out of park? I ran diagnostics and get a P0504. I have replaced the brake switch behind the brake pedal and still have the same problem. I am able to get it in neutral by turning the key but not turning the engine over. Once I get it to neutral then I can start the engine and it will let me shift to Drive. The problem with this though is that it will not shift up to the next gear. The dash also tells me that limited gears are available
Old Aug 15, 2023 | 07:36 PM
loanrangie's Avatar
Thats usually a faulty gear selector or cable requires adjustment.
Blamo35
Jun 14, 2022 08:58 PM
Colorado David
May 22, 2021 07:53 PM
Canizales
Dec 14, 2011 05:26 PM
FJL
Aug 20, 2009 12:10 PM
dustin1977
Mar 24, 2009 11:19 AM
