Clank when reversing and going forward
Old May 7, 2016 | 12:54 PM
Dirt Roamer's Avatar
Default Clank when reversing and going forward
Just wondering where to look next. I have a 2006 LR3. I'm getting a clank when reversing straight out of a parking spot and hitting the brakes. I have new front upper and lower control arms...front diff..front brake pads. I crawled under and visually inspected everything that has been replaced. It sounds like the noise is coming from the front.
Old May 7, 2016 | 05:47 PM
TOM R's Avatar
Rear drive shaft carrier bearing?
Old May 8, 2016 | 12:11 PM
KMET's Avatar
Check your front/back axle nuts too...
Improperly torqued or someone forgot to bend the tab.
Old May 9, 2016 | 08:31 AM
I recently had both diffs, drive shafts, control arms all replaced. Bearing should be good, but I'll still check. You never know haha.
Old May 9, 2016 | 08:33 AM
Thanks, I'll check the torque later today. The drivers side nut "tab" is bent, but passenger side has crown nut with no tabs.
Old May 9, 2016 | 06:15 PM
KMET's Avatar
Picture of said passenger nut. Castle nut? or, a nut from Crown Automotive?
there's no true tab, just tap/bend side of nut. Obviously re-torque it first.
Old May 9, 2016 | 10:13 PM
I was "picking up what you were putting down" on the tab.
Dealer called it a crown nut....looks like a castle nut to me.
Old May 9, 2016 | 11:52 PM
KMET's Avatar
That"s wrong nut.
Rovers north uses this...Is this what you have?
http://www.roversnorth.com/ProductDe...DRpRoCF5Hw_wcB
Go on Roverparts dot com, or local dealer pickup proper nut.
http://www.roverparts.com/Parts/RFD500020
24mm size nut
Old May 9, 2016 | 11:56 PM
KMET's Avatar
How are they locking it in-place?
Old May 10, 2016 | 04:27 AM
thorgal's Avatar
Old style ,early half shafts for LR3 need stake nuts whereas new half shafts don't.It is a different design.When I was ordering a driver's side on mine, I specifically requested an old style half shaft as I wanted to be consistent with parts, also had 4 stake nuts laying around as spares back then lol.
