Code p0138 help please
Old Apr 9, 2014 | 02:24 PM
Lr3pete's Avatar
Default Code p0138 help please
Hello to all you LR lovers out ther!
I have a 2007 LR3 HSECANADA, and I LOVE it!
My engine light has just come on. I took it to AutoValue and had the code read for me.
Code that comes up is P0138 and the message is "coolant temp below spec"
I had the cooling system flushed and the code reset....and it's back on again with same code.
I have read on here and looked it up online and p0138 says its an O2 pproblem.
I will take it to the stealer if I have to, but I was wondering if any of you could help me out with this...or at least put me in the right direction.
Thanks in advance
LR3pete
Old Apr 9, 2014 | 05:32 PM
LR Techniker's Avatar
Perhaps you misread/misheard that they said? Based on your code description, I would suspect it was actually a P0128, which is "insufficient coolant temp for closed loop operation". This fault usually points to a faulty thermostat (stuck open).
If your sure it was a P0138, that is indeed an O2 sensor code.
Old Apr 11, 2014 | 04:45 PM
BeachBumRover's Avatar
4th Gear
I had the same code in Dec. opened the t-stat housing and bam bad seal. Replaced it and have had no issue since!
Old Apr 12, 2014 | 10:10 AM
Lr3pete's Avatar
I am replacing the t-stat tomorrow, I'll let you know if it fixes the problem.
Thanks again
saltyrover
Apr 25, 2013 06:44 PM
sayeedA
Nov 15, 2011 11:02 PM
tango123
Sep 23, 2010 07:17 AM
jeffrudy
Mar 21, 2009 09:13 PM
