Coil conversion install questions
Old May 1, 2022 | 08:55 PM
toofaroffroad's Avatar
Default Coil conversion install questions
Has anyone installed the kit from Rover Parts recently? The printed instructions seem to end after the ground wired is connected with no explanation on programming or what to do next and when I watch their video it's a completely different module with a little button and reprogramming process. Man I'm confused. I've emailed them but figured I'd ask. Thanks for any help.
Old May 2, 2022 | 10:10 AM
Blackngold77's Avatar
unless the kit has changed since I did mine a couple years ago, you should get a small orange box for tricking the system after the install. There is also a printed sheet with pictures and instructions on how and where to splice the module into the wiring (it's under the steering wheel). When I got my kit, they supplied puncture splices so you didnt have to fuss with stripping wires.
Old May 2, 2022 | 12:43 PM
Yup, it's different. After two phone calls to them and also a call to Tom a Great Basin Rovers (AB sent me to him for help....kinda funny). The module is completely different. This makes the video they supply pretty much useless. The new module can only be hard wired in. No more ODB port and pressing buttons. You've gotta tap into the ECU, plug it all in and then start her up and everything should work perfectly. Also, they told me over the phone that I need to clear all the codes and disconnect the battery before module install. This info is not in the supplied instructions.
So, FYI, anyone buying this kit, you basically have to own a GAP tool and they don't mention anything about that before purchase or in the instructions. I gotta admit, I'm pretty bummed on the instructions and the help from them. If you are going to change something that crucial to the install and not even make proper updates it's gonna be a real headache for them moving forward. I have not even started the install and I'm already sweating. I'll update after it's done. Trying to be positive as the wiring and module install are sketchy looking.
Old May 2, 2022 | 02:27 PM
Weird, they must be sourcing from a different supplier.
I didnt have to clear codes or disconnect the negative before splicing in the old style one.
If you don't have a GAP tool, doing a hard reset with the battery cables should clear the codes for you as well. Though I'd confirm with them that it's sufficient.
Old May 19, 2022 | 10:16 PM
Just wanted to close this one up. I did the install. Everything worked. It was a SOB to get the coils in and the wiring was hectic but it all worked in the end. Link to my video.
toofaroffroad
Feb 21, 2022 10:45 AM
Eutopia
Jan 28, 2022 10:48 AM
Borga
Mar 4, 2021 01:32 PM
pipjack
Feb 21, 2010 09:26 AM
bennycisco
Jan 20, 2007 11:52 PM
