Cooland Leak Lessons Learned
Maybe this will help someone, I've had a coolant leak in my 06 LR3 since I bought it two years ago and replaced the reservoir initially but still smelled coolant - never could find the leak so after successfully installing an aftermarket nav and satellite radio last week I was encouraged and decided to find the leak. Found remnants of coolant above the water pump and decided to replace the pump never thinking that the thermostat housing could be leaking. Ordered the pump and while trying to remove the fan clutch broke the nipple off the top of the radiator. So, new water pump and radiator later, test drive revealed the Tstat housing was the culprit. Expedition Portal has a great write up on removal so I am now down to the old part off and getting ready to start installing the new housing which I ordered from LR of Merriam. While it's all fresh in my mind I thought I would post a couple of pointers:
Coolant usually doesn't flow up so if the coolant is above a component, chances are something above it is leaking.
The nipple on the passenger side top of the radiator is fragile.
LandRover sells just the radiator, you don't need the entire $600 "kit". LR part is LR021777. LR Merriam had the Radiator for like $350 and the housing for just over $100.
I was able to get the housing out without removing the fan clutch a second time, I would have but somehow it won't come loose even with a fan tool and large hammer. (Watch that nipple).
In retrospect I wish I had bought all new replacement hoses since I've had most of them unhooked during this process.
Anyway hope this helps someone save a few hundred dollars and several hours. I do have a question, why is it that every project a man does, the wife asks "how much longer is it going to take?"
