Coolant leak from around recent Thermostat housing..
Old Oct 14, 2020 | 11:34 AM
Athana's Avatar
Default Coolant leak from around recent Thermostat housing..
Hi..I started smelling coolant..again..it's like a curse with this car.. Mechanic did a pressure test..coolant coming out of Thermostat Housing..the one held together with 3 screws.
This Thermostat Housing was just replaced last year..? I don't get it the original lasted 170,000
miles ?
It was put in (the whole thing was something like $450 I vaguely remember) last November.
So this other mechanic says needs a new gasket ( but this thing is newish) and puts a silicone around the opening to see if holds.Still leaking..
Mechanic who put this part in in November said still warranty and is getting another gasket..
I mean..is this going to solve it or is this a bum part that should be replaced? Thanks for the great help you have always given.God bless
Old Oct 14, 2020 | 11:37 AM
did they get genuine or a cheap knock off?
I have had great luck with the genuine they come with all the new seals etc
Old Oct 14, 2020 | 06:10 PM
pagoda's Avatar
miles ?
Did you replace the whole assembly (the thing that looks a bit like a manifold) or just the thermostat housing. For the price you say you paid - which in my view is high - I assume you got the whole thing plus coolant. If that's the case they wouldn't have removed the thermostat itself (it's part of the bundle) in which case I'd say either poor fitting, or faulty part.
TennRover
Sep 28, 2019 07:45 AM
Tratcliffe
May 4, 2016 07:12 AM
rzuluaga
Dec 18, 2015 11:54 AM
danvlarsen
Oct 20, 2010 12:20 AM
Trickymonk
Sep 12, 2009 08:29 AM
