Coolant leak. Please help
The leak is most likely the weep hole or gasket on the coolant pump that is directly above it.
Hope that helps
Jeff
General Disclaimer: I might be Wrong
I tend to agree with Ruff, because that actually location circled is for the oil cooler but just oil flows in/out. With that said it is a double o-ring that does tend to leak at some point, easy to replace. The actual coolant flows in rubber hoses closer to the filter. So agreed that its a leak from above hitting there.
ZMonet
06-24-2016 04:00 PM
oysterhead
05-16-2011 10:42 AM
chendricks207
01-07-2010 08:25 AM
