Coolant leak. Please help
Old Apr 27, 2021 | 10:01 PM
Ponoka651's Avatar
8th Gear
Default Coolant leak. Please help
I have this coolant leak. Can anyone help me by telling me what the part is that it’s leaking from?
Old May 1, 2021 | 10:06 AM
Rufflyer's Avatar
The part is the coolant /oil cooler (where the oil filter screws onto).
The leak is most likely the weep hole or gasket on the coolant pump that is directly above it.
Hope that helps
Jeff
General Disclaimer: I might be Wrong
Old May 2, 2021 | 09:06 AM
DakotaTravler's Avatar
I tend to agree with Ruff, because that actually location circled is for the oil cooler but just oil flows in/out. With that said it is a double o-ring that does tend to leak at some point, easy to replace. The actual coolant flows in rubber hoses closer to the filter. So agreed that its a leak from above hitting there.
ZMonet
Jun 24, 2016 04:00 PM
oysterhead
May 16, 2011 10:42 AM
tflhund
Dec 30, 2010 09:54 AM
chendricks207
Jan 11, 2010 03:21 PM
chendricks207
Jan 7, 2010 08:25 AM
