Corrosion at EAS Compressor Mount?
Old Jul 20, 2025 | 11:12 AM
james.martin1's Avatar
Default Corrosion at EAS Compressor Mount?
It looks like i'm getting some rust on the frame behind the compressor bracket. Thankfully just surface rust but I don't want to let it get any worse.
Back in 2023 soon after I purchased the truck I found the compressor mount had corroded away where it attaches to the frame. I replaced the mount, bolts and u-nuts then coated the frame with fluid film. It seems like now the steel frame is corroding faster than the aluminum mount, and rusting a little faster than the rest of the frame which still has most of it's paint.
Has anyone else delt with this before? Is there a method to isolate the mount to stop the galvanic corrosion?
Motivatedsellerct
Oct 25, 2021 07:48 PM
Micmac
Mar 27, 2021 03:48 PM
DoubleK
Jan 8, 2016 03:49 PM
newpassion
Mar 2, 2014 12:57 PM
Charles68
Oct 27, 2010 11:18 PM
