CV/half shaft stuck
Old 10-30-2019, 08:35 PM
Charliegeosci's Avatar
Default CV/half shaft stuck
So, I知 replacing my drivers side front left half shaft due to it failing on the road. I managed to pull out the part connected to the wheel hub and the shaft. However, when I pulled the shaft, it tore the boot on the inner section, closest to the transmission casing.
I cannot get it out the remaining hexagonal type looking piece. I have tried a couple of different things to try and pry it out, but I am worried that I may damage the small lip on the transmission casing. I bought a small sledge thingy to try to leverage it out, but no luck. The snap ring is really holding it in there very well. Any tips to get it out?
I cannot exactly lift it higher than about 2.5 feet off the ground with my garage jack, and I just moved from Alaska to Seattle, so space for working on your own car is non-existent.
I failed to take a photo but I may take one if I get down there again soon.
Old 10-30-2019, 09:12 PM
jagmandan's Avatar
They can be a bear. I had luck putting outward tension on it with a ratchet strap and then tapping with a pry bar & hammer.
Old 10-30-2019, 09:23 PM
DakotaTravler's Avatar
^ I was just going to suggest the same. Wrap it good and tight so the strap will not slip.
Old 10-30-2019, 09:28 PM
Received 1,590 Likes on 1,306 Posts
We applied tension with a winch and one good smack from a 3 lb finishing hammer saw it shoot loose
Charliegeosci (10-30-2019)
Old 10-30-2019, 09:46 PM
I did not think of a ratchet strap!! Awesome, I値l try that
Old 10-31-2019, 11:50 PM
razorkill12's Avatar
I have used a slide hammer with an attachment for vice grips/locking pliers.
Charliegeosci (11-01-2019)
Old 11-01-2019, 07:30 PM
Cool. Didn稚 know that was a thing. I値l check it out if the ratchet strap doesn稚 work
Old 11-17-2019, 07:06 PM
Thank you!!
mthe sldie hammer worked, but not until I found online that you can get a specific attachment for the slide hammer that fits the cv joint, and it grabs it around the waists, for lack of a better term.
it came out. I was super happy!! I just not need to actually pry off the steering knuckle to be able to gain the clearance to insure the spline section into the wheel hub. I just ordered the tool and have it in hand know (ball joint puller). It should go smoothly from here! I値l post updates about it when I get time to work on him again.
Old 12-01-2019, 11:56 PM
Hey, the slide hammer worked!
i had an issue with the steering knuckle ball joints. Do they need to be pressed in when you reattach them? It came out of the mount and the wheel came off, basically ripping out all the work I just did.
Old 12-02-2019, 12:00 AM
Steering knuckle? Not sure what you are talking about.
Quick Reply: CV/half shaft stuck
