CV/half shaft stuck
Old Oct 30, 2019 | 08:35 PM
Charliegeosci's Avatar
Default CV/half shaft stuck
So, I’m replacing my drivers side front left half shaft due to it failing on the road. I managed to pull out the part connected to the wheel hub and the shaft. However, when I pulled the shaft, it tore the boot on the inner section, closest to the transmission casing.
I cannot get it out the remaining hexagonal type looking piece. I have tried a couple of different things to try and pry it out, but I am worried that I may damage the small lip on the transmission casing. I bought a small sledge thingy to try to leverage it out, but no luck. The snap ring is really holding it in there very well. Any tips to get it out?
I cannot exactly lift it higher than about 2.5 feet off the ground with my garage jack, and I just moved from Alaska to Seattle, so space for working on your own car is non-existent.
I failed to take a photo but I may take one if I get down there again soon.
Old Oct 30, 2019 | 09:12 PM
jagmandan's Avatar
They can be a bear. I had luck putting outward tension on it with a ratchet strap and then tapping with a pry bar & hammer.
Old Oct 30, 2019 | 09:23 PM
DakotaTravler's Avatar
^ I was just going to suggest the same. Wrap it good and tight so the strap will not slip.
Old Oct 30, 2019 | 09:28 PM
We applied tension with a winch and one good smack from a 3 lb finishing hammer saw it shoot loose
Old Oct 30, 2019 | 09:46 PM
I did not think of a ratchet strap!! Awesome, I’ll try that
Old Oct 31, 2019 | 11:50 PM
razorkill12's Avatar
I have used a slide hammer with an attachment for vice grips/locking pliers.
Old Nov 1, 2019 | 07:30 PM
Cool. Didn’t know that was a thing. I’ll check it out if the ratchet strap doesn’t work
Old Nov 17, 2019 | 07:06 PM
Thank you!!
mthe sldie hammer worked, but not until I found online that you can get a specific attachment for the slide hammer that fits the cv joint, and it grabs it around the waists, for lack of a better term.
it came out. I was super happy!! I just not need to actually pry off the steering knuckle to be able to gain the clearance to insure the spline section into the wheel hub. I just ordered the tool and have it in hand know (ball joint puller). It should go smoothly from here! I’ll post updates about it when I get time to work on him again.
Old Dec 1, 2019 | 11:56 PM
Hey, the slide hammer worked!
i had an issue with the steering knuckle ball joints. Do they need to be pressed in when you reattach them? It came out of the mount and the wheel came off, basically ripping out all the work I just did.
Old Dec 2, 2019 | 12:00 AM
Steering knuckle? Not sure what you are talking about.
