Probably connectors. Check front and rear. Maybe a rear was never plugged in correctly and came out (doubtful, but ya never know).
Land Rover 3 ambigos solved 100% with proof)
Below the front right foot mate lots of cables are going backwards from the firewall , wity in these cable is a connection with splicers which is broken or rusted that causes initially intermittent and later on permanent break fault ( 3 amigos hdc , suspension , and special program off faults) here is a link which is not very clear but enough to work on !! Land Rover 3 ambigos solved 100% with proof) |
I've just been down the rabbit hole of pulling out the CJB, fixing the sunroof drain line (had to put in a new line from the A-Pillar down) and of course, buttoned it all up. I found this thread on the Disco3 Forum. Super helpful to visualize, for me, the process:
Make sure relays are off the CJB. That'll give you some more room. Start by laying in the footwell looking up. Put the box in 90º-ish opened up to the inside of the truck 1 plug red 2 plug green 3 box in position 4 plug-in bigs 5 plug down (green) 6 fixed box https://www.disco3.co.uk/forum/topic122639-15.html Once I had this in my mind, it took me about 30 minutes to hook it up and have the CJB mounted. I did take a few test runs. Now all I need to do is repatch some wiring that has corroded and dry it out. And troubleshoot from there. Yay. |
