Disable Headlight Washer ?
I usually keep the Rover clean and as soon as those Headlamp Washers go off, there is always wind blown spray that comes up on the hood or creeps around the sides. It's a Black car also !
Yes they do bother me quite a bit. I live in Socal and do not go mudding or really ever have had the need to clean my headlights while driving. I do however sometimes need to clean the windshield while driving at night. Either from bugs or whatever.
To live in Southern California....My Java Black Rover is currently road grime grey. It is so thick you can't even tell it is a black vehicle. Only 6 months till spring!
ps. I love my headlight washers. No more rubbing handfuls of snow on them so you can see the road...
Headlamp pump is on the left.
If you are really keen on disconnecting the headlight washer pump, probably disconnecting the power cable is the way to do it.
I tend to agree, black paint and every day is sunny, it does not sound like headlight squirter's are really needed - save the water for the windscreen. Probably you often operate the windscreen squirter's just to clear the lines so to speak so that deposits from the heat evaporated water do not plug up the windscreen jets.
Up here, I find that snow works better anyway - the antifreeze type -40F washer fluid "water" we use just turns to ice anyway, particularily on the headlights as they do not generate very much heat. The heated windscreen is really useful here.
The headlight washer pump is the large one on the left in the picture; the apparently smaller hidden one to the right is for the windscreen. That must explain why regardless of how low I seem to have the windscreen jets aimed, the hood gets squirted instead, however the windscreen just seem to get damp when the windscreen squirter is activated - maybe all the water is going to the rear glass.
The jpg is what you see if you remove the left front plastic wheel well liner.
