Discovery LR3 Comms Fault- Bus Signal B00D2
Old Aug 9, 2020 | 12:43 AM
Andrew kiwi's Avatar
4th Gear
Default Discovery LR3 Comms Fault- Bus Signal B00D2
Greetings Tech Brothers,
Could I kindly speak to an intelligent life form with grey hair and wrinkles who worked on these things in 2005 to 2009 please?
Fault- B00D2 - Restraint System Malfunction Indicator 1
History - Flood in left side foot well- front and rear of a Right hand drive LR3
Tool -ICARSOFT LV2 Landrover scanner-real time results.
Thankyou
Old Aug 10, 2020 | 02:47 AM
4th Gear
Default LR3 Airbag Comms Failure - help please dont be intimidated!!!
Hi guys ,
Thank you for your time..
This fault is a very tricky one that tests your intellect.
Heres a quick brake down of comms fault.
The SRS readout on right of the dash is active .
Air Bag light is lit to "40% only."
All resisters inside the Airbag circuit are of similar value
All steering buttons work ok.
Sky light leaked
Un plugged rectangle plugs front seats only and cleaned with CRC Contact cleaner and re fixed retainer hex screw.
Fault returned after clearing error with Icarsoft tool , but returned again after restarting Car.
So Lads,
I am wondering about the following .
1 . Does a faulty leaky drain leak onto a central fuse box somewhere around front passengers foot well, providing power to the SRS restraint circuit ?
2 . Dimly lit Air bag light might mean low power from fuse box to RCM restraint module activating a comms error alarm?
3 . an Earth point or Earth common connectors somewhere in floor or sill area that may have water damage .
4 . How to test safely -the cambus signals across the various points of th SRS circuit.
What would be really awesome to see some pictures of the Earth points - Connectors relating to Airbag Circuit - RCM Module removal - Door Airbag hing Plug - Fuse bank and anything you have.
Thanks Lads .
Wife has given notice that the Dog house has been prepared for me, and the Dog gets my bed if this
problems not fixed .
The Pressure is ON.
freeski27
Jul 31, 2020 08:15 AM
KKN
Jun 23, 2013 12:04 AM
anhernandez
Aug 18, 2009 12:47 AM
carlitonsky
Appearance & Camping Set Ups
Nov 27, 2008 11:59 PM
