dumb question re: gas light
Old Jun 10, 2010 | 08:20 AM
magoo1113's Avatar
Default dumb question re: gas light
sorry, dumb question but i can't find answer anywhere - how many miles left in the tank once the gaslight comes on? just need to know if i can make it to a station. thank you!
Old Jun 10, 2010 | 09:39 AM
d2luvr's Avatar
Why would you risk burning up a $350 fuel pump? The pump is cooled by the fuel in the tank and if it is less than 1/4 full it can't cool the pump and it will burn it up.
Old Jun 10, 2010 | 10:41 AM
magoo1113's Avatar
It's the first time in 7 years and 2 land rovers the gas has ever gotten below 1/4 of a tank, hence me not knowing how many miles I have to go. An emergency caused me to have to get somewhere quickly, not that that is anyone's busy. While I appreciate your concern for my fuel pump, I would have appreciated more assistance with how many miles I have left to get to gas station. Thanks.
Old Jun 12, 2010 | 09:55 AM
Rovin4life's Avatar
miles means nothing. its down to the amount left which isnt that much. Maybe 20 miles if on a highway but looking at the guage it should say how much is left on the instrument cluster. But its not perfect. Three miles might be ten and zero miles might be two or Vice versa. If its low get it filled. Common sense.
Old Jun 12, 2010 | 06:04 PM
Navy_Jak's Avatar
Default Message Center, toggle to Range
magoo1113,
Depending on your driving style, the Range counter might help you determine how many miles b4 empty.
Push the button located on your turn indicator switch on the steering wheel and toggle to Range.
Hope this helps.
OBTW, I've been there b4 where I see the empty light and hope I get another 10miles on it to get home, where I left my wallet. I won't do that again.
Regards!
Old Jun 14, 2010 | 06:05 PM
CopperMtnGuy's Avatar
About 20 miles, that's what I get. Usually fill up when the light comes on. Always have, never burned anything up.
Old Jun 17, 2010 | 03:42 PM
MJ2's Avatar
MJ2
My experience is once it gets to 60 miles to go, it nose dives quickly. Never ran out, but it can drop from 60 to 20 in nanoseconds....
Old Mar 11, 2023 | 03:19 PM
Dr.Do.'s Avatar
Default I have the exact specifics. I was curious to find out so i risked my fuel pump :P
11 miles since light onAverage speed - 65-70 mphGas to fill 20.8 galGas tank cap. 22.8I would say you have 2.5, 3 gal maximum after gas light come on
Old Mar 11, 2023 | 09:04 PM
elemental_garage's Avatar
Sounds like you need to push it and tell us when you run outta fuel. For science!
Old Mar 12, 2023 | 08:38 PM
DakotaTravler's Avatar
100% false... The LR3 uses a swirl pot. Pump is always submerged in fuel until one truly runs out of fuel.
