EAS Help!
Old Nov 5, 2016 | 08:51 AM
Lsbbigdog's Avatar
Default EAS Help!
I purchase a 07 LR3 a little over a month ago . I noticed it started to drop like an 1" or so overnight .I brought it back to the dealer and they sprayed everything with a solution to inspect for a leak. No leaks were found but it still drops more now that its getting cold at night.
I read to pull the fuse #26 overnight to possible indicate what's dropping but when i opened up the fuse compartment I noticed #28 was missing . I this something I should rwplace or was it pulled because of an issue?
Any help of these 2 issues would be much appreciated!
Old Nov 6, 2016 | 06:00 AM
Lsbbigdog's Avatar
After sitting overnight with the fuse pulled just the front dropped equally on both sides. So just front valve block issue?
Old Nov 9, 2016 | 12:19 PM
AdrenalinPlease's Avatar
Most likely, remove the valve block and clean it internally. put it back on and retest
Old Nov 9, 2016 | 12:36 PM
Lsbbigdog's Avatar
Thanks
I replaced the valve block Monday and no more dropping. Now to figure out the fuse being pulled to the air dryer
simjack
Oct 12, 2008 10:24 AM
Handy930
May 10, 2008 10:16 AM
range_rovin1986
Jan 10, 2007 05:49 PM
Jim99
Oct 27, 2006 07:14 PM
daveo
Sep 23, 2006 06:37 AM
