easy entry
Old Aug 5, 2005 | 03:49 AM
mowensmd's Avatar
5th Gear
Default easy entry
Page 92 owner manual:
Programming selections:
one option mentioned after "right rear view mirror" is called "easy entry" in the manual.
but when I scroll through the menu in my car it jumps from rear view to "restore default settings"
Anyone understand?
Old Aug 5, 2005 | 11:44 AM
auburndmbfan's Avatar
4wd High
Default RE: easy entry
What model do you have? "Easy Entry" is only available on the HSE model, which has Memory Seating...
Old Aug 7, 2005 | 11:17 PM
mowensmd's Avatar
5th Gear
Maybe that's it, we have an SE. But isn't memory seating on the seat with the HSE? What does easy entry do?
Thanks, just curious.
Old Aug 8, 2005 | 11:39 AM
4wd High
Good question - it's one I posed in this thread: https://landroverforums.com/m_4729/tm.htm
I still don't have an answer, and I have an HSE and have "Lazy Seats" and/or "Easy Entry" turned on..
Old Oct 3, 2005 | 10:25 AM
RATCHET's Avatar
I THINK YOU WILL FIND EASY ENTRY CAN BE SET BY YOUR REMOTE KEY FOB ONCE PRESSED IT WILL LOWER THE CARS SUSPENSION TO ITS LOWEST SETTING AS LONG AS YOU HAVE THE AIR SUSPENSION MODEL
Old Oct 9, 2005 | 11:15 AM
rinmud's Avatar
all of them in the us market have programable (air suspension) the key needs to be programed to make the air suspension go down its a simple procedure outlined in the manual. There are a few other features I was instructed at school that also can be done but rover thinks americans are too stupid to utilize without a line forming at the dealership for lessons
Old Jul 31, 2011 | 02:27 PM
jbb611's Avatar
Default Clarification
rinmud,
being a master tech perhaps you could clarify a few items from the LR3 manual. This all pertains to Remote handset, and functionality. I will use only LR3 manual language in quotes and underlined for reference.
My Vehicle: LR3 HSE Air Suspention, memory seats.
1) PG 35. Item 3. "Unlock button: press once to disarm the alarm, unlock the drivers door and activate the "convenience seats" feature, see (Drivers Seat Memory Facility*, 53). Press once to activate the memory seat and mirror settings."
Flip to page 53. Followed instructions for setting memory pre-sets. Done. Flip to Next Page. Page 54 ..."Convenience seats* When convenience seats option is selected and the vehicle is unlocked using the handset, the vehicle adjusts the driver seat and the exterior mirrors to the position associated with that particular handset."
QUESTION 1: Since my vehicle can memorize up to three different driver seating positions for each of the three possible ignition keys...which position is associated with the handset. Which position does it deem to be convenient?
Hopefully you can see the lack of clarity here.
2) Still on page 54. "Convenience seats can be selected or deselected...by selecting settings (see SELECTING SETTINGS OPTIONS, 91)"
Flip to page 91. Flip to page 92.
QUESTION 2: Please tell me where I can find, ON PAGE 92, a setting option for Convenience seats......I do see a setting for Easy Entry, which you have stated is a feature of the handset that lowers the vehicle, but I was referred to this page to create setting for convenience seats which should recall one of three (undetermined) seat and mirror settings.
QUESTION 3: Please direct me to the page in the manual that describes Easy Entry.
You mention the "simple procedure outlined inthe manual". Its called "Air Suspension Control" and is described on PG 38. Yes Ive used that "simple" procedure and programmed my key to lower and raise the vehicle,...but nowhere in this "simple procedure" does it state this being called "easy entry".
QUESTION 4
: Are "easy entry", "convenience seats" and "memory seat and mirror settings" all the same? Or are they different. Is it possible that master techs are even confused by the terminology?
Question 5:
Still wondering which memory seat setting is activated when i unlock by pressing the handset once. Because my wife who primarily drives the car and has seat setting 1 programmed for her, always has to manually adjust the seat (note: easy entry is "on" in settings)
I appreciate any explanation. Hope this was less confusing than the manual.
Frank4
Mar 21, 2014 05:21 AM
dragan
Mar 10, 2009 08:30 PM
faith2
Sep 14, 2005 03:04 PM
FORDSTANGER
Aug 9, 2005 01:00 PM
pvalianatos
Mar 12, 2005 05:20 PM
