eBay key stopped working, battery shows 3.3v
Old Mar 11, 2020 | 11:18 AM
douglastic's Avatar
Default eBay key stopped working, battery shows 3.3v
Is there ever a need to re-pair a key fob to a vehicle?
They should never get dropped right? eBay key has worked for I think 2 yrs now just fine.
It even has a Maxell Rechargeable inside!
So last week it just stopped locking/unlocking. Still works in the ignition.
Battery shows 3.3v but I don't know if it is just not sending a signal anymore?
Can IIDtool check this - whether a key is "talking" to a vehicle? OEM fob still functions fine.
Maybe its just not worth any detective work - I could just swap the 14yr old OEM key board to the eBay shell using the new Maxell battery.
And just get a new eBay key again. Cheap enough.
Guess I just answered my own post haha
Old Mar 11, 2020 | 11:34 AM
Friday Night Disco's Avatar
Does the red led come on when you depress the button?
Old Mar 11, 2020 | 12:37 PM
douglastic's Avatar
I see no LED anywhere - do you mean an LED in the fob? or in the LR3 dash?
All buttons have a normal positive feel
Old Mar 11, 2020 | 12:46 PM
Key fob should have a red led when you depress button
Old Mar 11, 2020 | 12:47 PM
douglastic's Avatar
I can inspect again tonight
but not sure the eBay key ever had one
Old Mar 11, 2020 | 01:52 PM
houm_wa's Avatar
There is no LED on the LR3 key FOB.
Old Mar 11, 2020 | 02:01 PM
Blackngold77's Avatar
Sounds like the rechargeable battery in the ebay key was junk and died on you.
Old Mar 11, 2020 | 02:20 PM
douglastic's Avatar
It is measuring 3.3v tho
Can I piggyback a 2nd 3v battery (parallel) to test this w/o damaging the potentially already damaged circuitry?
edit: Probably not a good idea - I suppose the $15 I spent on the fob was cheap for 2yr use - rinse and repeat
Old Mar 11, 2020 | 04:23 PM
This...
Old Mar 15, 2020 | 03:55 AM
Globetrotter448's Avatar
You can get a "dry joint" on the key fob circuit board, worth taking to bits and checking although a new battery is cheap enough
