ECU update for switch new compressor (AMK)
Old Sep 10, 2014 | 08:41 AM
flwoodsman78's Avatar
Default ECU update for switch new compressor (AMK)
I just replaced my old Hitachi compressor with the newsest AMK unit. It may be a couple weeks before I can get it in to get the ECU updated. Would it be alright to drive it for now? Will I get any ECU related suspension fault codes until I get it updated? I'd hate to mess up a brand new compressor. Thanks.
Old Sep 11, 2014 | 03:00 AM
superkev's Avatar
What i did in the interim when i did mine was this: turn engine off and then turn it on again, turn wheel fully to the right, then turn fully to the left and then back to the middle again, turn engine off and then on again.
This should reset the warnings; it did to mine.
On the point of messing up your compressor, i would probably just drive it in normal mode at reasonable speed until you sort it out.
good Luck
Old Sep 13, 2014 | 07:25 AM
roverguy7's Avatar
It will not damage the compressor, however it will throw faults if the compressor runs for a period of time, longer then just the initial top off it does at start up.
The biggest difference in the software is temperature monitoring. The AMK uses internal control for the motor temp, which is not reported back to the ECU like the Hitachi. So if it runs to the point where temperature should change, and the ECU sees a difference in value between motor and compressor temp inputs, a fault will be thrown.
There are other changes in the software too, such as exhaust valve strategy, but nothing that will be detrimental for a short period of time.
jafir
Aug 12, 2021 08:36 PM
houm_wa
Aug 6, 2015 08:44 AM
arnottdoug
Member Group And Special Buys
Nov 14, 2014 01:05 PM
Paul Grant
Aug 10, 2014 12:29 PM
