Electrical short killing battery
Battery light came on ... within 24 hrs, vehicle revs started surging (similar sound to whoosh @ start up) ...HDC fault in mess.ctr. ...upon testing, battery was dead and alternator was cycling trying to charge and down and trying again etc...
After installing a new battery, a shorting smell was detected, and the battery was drained fully!!
Any help would be appreciated
Check carefully the wiring to the starter, I believe bbyer documented a rub short from that cable some time ago. Otherwise it's going to be the hunt and peck method which may take some time. Remember, most systems have no power when the vehicle is off, so it's likely fairly close between the battery / alternator and fuse boxes.
DakotaTravler (12-13-2023)
