Electrical short killing battery
Old Sep 20, 2014 | 12:01 PM
PeetzLR3's Avatar
Default Electrical short killing battery
Battery light came on ... within 24 hrs, vehicle revs started surging (similar sound to whoosh @ start up) ...HDC fault in mess.ctr. ...upon testing, battery was dead and alternator was cycling trying to charge and down and trying again etc...
After installing a new battery, a shorting smell was detected, and the battery was drained fully!!
Any help would be appreciated
Old Sep 22, 2014 | 12:12 PM
unseenone's Avatar
Check carefully the wiring to the starter, I believe bbyer documented a rub short from that cable some time ago. Otherwise it's going to be the hunt and peck method which may take some time. Remember, most systems have no power when the vehicle is off, so it's likely fairly close between the battery / alternator and fuse boxes.
Old Dec 11, 2023 | 01:02 PM
katsnelson's Avatar
Question Electrical short
My 2009 LR3 electrical just died completely. Had it towed to a mechanic and he believes it is a major short circuit. He connected a small booster battery and the cables became very hot and the booster refused to provide charge. Any suggestions on how to locate the short?
Old Dec 11, 2023 | 11:21 PM
loanrangie's Avatar
Alternator is dead, they go open circuit and drain the battery and if not fixed can destroy electrical systems.
CarGuyNye
Feb 22, 2024 11:02 PM
RizzleKicks
Nov 7, 2021 10:19 PM
86v8
Feb 14, 2018 03:47 PM
2000 Disco 2 SD7
Jan 25, 2009 02:59 PM
yarddawg
Jan 15, 2008 07:40 PM
