Engine Mounts
Old Apr 14, 2021 | 08:20 PM
Aaron Betz's Avatar
Default Engine Mounts
I hear a clunk coming from the engine bay every time I hit a bump. I’m pretty sure it is the passenger side engine mount. Has anyone ever replaced one of these? I know with the discovery II it’s easy to do with a floor jack underneath the engine. Thanks in advance.
Old Sep 19, 2022 | 11:37 AM
RoverSE7's Avatar
Bump! I am also in need or both side Engine AND transmission mounts due to a small bump to a truck rear end accident. No damage to frame or anything just the plastics on the bumper but totally snapped the old rubber engine and tranny mounts moving the whole engine an tranny at least 1 -1/2 inches forward. SMDH
Old Sep 19, 2022 | 06:53 PM
SeattleDriver's Avatar
Here are the procedures for removal and replacement of the 4.4L V8 engine mounts.
File Type: pdf
File Type: pdf
Old Sep 20, 2022 | 05:41 AM
RoverSE7's Avatar
Hmmm These seem to be instructions for ball joint Installation
Old Sep 20, 2022 | 08:39 AM
I just checked and those are the correct JLR procedures. They suggest you remove a lot of components in the wheel wells for access.
Old Sep 20, 2022 | 11:05 AM
RoverSE7's Avatar
Why in the world would you remove the ball joint to remove the Engine mount . The Rave makes no reference to this
Old Sep 20, 2022 | 12:41 PM
I thought RAVE only extended into DII. From LR3 and on they switched to TOPIX, which is what I provided. I’ve not changed engine mounts, so perhaps it’s not necessary, but the sides of the engine bay are pretty tight.
I’d probably first attempt changing them from the bottom as shown in your manual, but wouldn’t be surprised if going in from the side was easier in the end.
Please report back on how you accomplished it, I’ve wondered about this procedure myself.
Old Sep 20, 2022 | 12:46 PM
RoverSE7's Avatar
Oh well that is a different Story... This is a LR3 Thread No wonder. Sorry about that Bud
Old May 26, 2024 | 05:44 PM
E’s2011LR4's Avatar
7th Gear
i just did this in my LR4
it didn’t seem like popping the ball joint would’ve helped at all. I had to lower the front diff to pull the part out of the tight space.
Lisa Bunch
Apr 1, 2019 09:39 AM
Sixpack577
Oct 10, 2017 09:27 AM
Daedrix
Sep 26, 2016 01:40 PM
04duxlr
Sep 22, 2014 07:38 AM
EricTyrrell
Nov 21, 2011 12:18 AM
