EPB question, totally stumped
Old Feb 15, 2026 | 03:28 PM
Tristan Stumpf's Avatar
Default EPB question, totally stumped
Hello, I replaced the gears in my EPB because they were all chewed up to bits.
I put everything back together and adjusted the brakes (new shoes)
I put everything back together and it's not working. The module makes a weird noise then throws this code (attached)
Not sure what I did wrong here.
https://youtube.com/shorts/nQN7bLDTfdc?si=gFl_gcW6nxUD96Bd (video of noises)
Old Feb 15, 2026 | 07:02 PM
DakotaTravler's Avatar
That image makes it look like the cables were fully retracted if I am not mistaken, could be tho. So if you did not wind out the cables, effectively manual setting service mode, the EPB is already maxed out and can not retract.
Old Feb 15, 2026 | 07:05 PM
Okay, did some digging. Looks like even if it the cables were in that position when you set service mode, now with working gears, it would have backed off the cables anyway. Did you set service mode before adjusting the brakes? If not then set service mode and adjust again.
Old Feb 17, 2026 | 04:04 PM
Thanks so much for the reply,
For added info, I have no error codes, a flashing red parking brake light,
When I try to enter service mode it seems like nothing is happening, unless I am doing something wrong.
Old Feb 18, 2026 | 03:35 PM
Rufflyer's Avatar
Default service mode
How did you enter service mode?
Did you use your launch diagnostic tool, or the EBD press method?
Jeff
Old Feb 18, 2026 | 05:39 PM
I wonder if you have to clear codes for it to enter service mode, not sure. When you enter service mode you should, in theory, hear the parking brake module briefly back the cables out.
Old Feb 19, 2026 | 12:23 AM
Default Service mode
Jeff
I haven't been able to enter service mode. As far as I can see, my Launch tool doesn't support it as far as I can tell. I've tried the brake bible process also and nothing seems to happen.
Old Feb 19, 2026 | 12:26 AM
Thanks,
I've tried entering service mode, with and without codes on the module. I can't get it to try and back out the cables.not sure if this matters but the dashboard parking brake light is blinking constantly.
Old Feb 19, 2026 | 08:36 AM
Rufflyer's Avatar
Default You may need to remove the unit and reinstall the cable correctly
Based upon your video I think the EPB tries to tighten the cable, hits the end of the threads then meets the torque limit and then backs off and keeps doing that as long as you hold the lever up.
Sorry, but I think you need to remove the EPB module disconnect and reinstall the cable with the the treads and square block with only in 5 turns before tightening the outer sleeve. (you may be able to remove the cover, disconnect the cable and reinstall while still in the car, but it could be difficult).
Bodsys Brake Bible is a great book and is very useful, but it does not cover what goes on inside the EPB unit itself.
The Service manual treats it as a replacement only part. No internal service available.
There are many videos showing how to service the EPB and how to adjust the latching cables.
Let us know what you find.
General Disclaimer: I might be wrong.
Jeff
Old Feb 19, 2026 | 10:11 AM
Rufflyer's Avatar
I don't remember forum link rules so I recommend looking at the Discovery 3 & 4 Range Rover Sport - Electronic Handbrake Cog Replacement video on Youtube
Does your launch diagnostic tool have an unjamming procedure? I would try that first.
