Falcon website out of T bleeder valves? Whaddya think of this?
I copied what someone else did on another thread here. He used a 1/4 pipe tee fip, (2) 3/8 x 1/4 mip hose barbs, and a 1/4 square hose plug. He said it worked fine. My other LR3 has the Falconworks brass T bleeder. My question is ~ will those side barbs loosen and unscrew? The whole point being that the OEM bleeder disintegrated over time unexpectedly. I dont want the irony to be this one unscrewing and leaking coolant and...you know the rest - Whaddya think guys? (For my 2nd LR3)
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh!! I picked up silicone gasket. I think I need the thread lock seal instead.
Hiya. I picked up some Permatex Red RTV high temp silicone. Will that work? Thx. Doh! This is the wrong one. I need thread sealant / lock.
or they seep. And by the time it's cool enough to redo it with sealer you've compoletely forgotten about it and moved on to other chores.
The homemade brass tee setup you have there will work just fine and will likely never fail again, but is overkill and a bit more expensive than necessary in my opinion. When I priced out that exact setup to fix my LR3 a couple years ago, it added up to over $20 in fittings (maybe I shop at the wrong places). I've never used the upper bleeder so I "straight piped" it like douglastic described above and have never had an issue.
The straight pipe idea is really a better way to go, didn't think of that at the time I needed my tee-when mine went, I had smelled some coolant, saw the tee weeping and said "hmm", touched it and it exploded at my touch. I was liucky to not get coolant burns.
