Fattest tire....
Fattest tire....
I am by no means an off-roader, but I do like the visual of the LR3 with some presence.
Does anyone know the widest tire that can fit w/o having it rub while turning. I am thinking at 275 is about the max without Rubbing anywhere...
i have some Johnson type rods that were installed by the previous owner...(height I know is about 32 no more with lifts etc)
Concur with Doug. I ran 285/60s for a while and had no real issues with rubbing. The wider stance does look cool. It's 285/60R18 to be exact, so if you have an HSE but don't have 18" rims that won't work but you could still shoot for that same width, just in a 19. I've never looked to see if there are any options there.
A 275/65R18 will fit in the spare tire well if you remove the heat shield and air it down some. Don’t know how easy it will come out, but it does fit.
Are your tires E-Load range? I think they are larger diameter than an XL or Regular Load range tire, due to the deeper treads.
Maybe XL fit better than E underneath?
