Faults listed
Old Aug 1, 2024 | 12:48 PM
peter220nyc's Avatar
4th Gear
Default Faults listed
Have no Idea where to begin. where do i start with all these faults. car runs fine no light indicator but my rear passenger windows wont roll up or down. Just had an oil change, replaced the serpentine belt and tire rotation. any guidance is appreciated in advance
Model L319 - LR3 2007
Vehicle scanned on Aug 1, 2024 12:52:12 PM
IIDControl 4.2.6 Build 158 Android - IIDTool BT V4.0 B3906
Body Control
B1C59-14 - Electric door window glass relay output circuit - General electrical failure - circuit short to ground or open (2B)
( on 03-07-2024 02:17:18 at 161556 mi )
B1D14-15 - Interior lamps 2 circuit - General electrical failure - circuit short to battery or open (2A)
Instrument Pack
U0132-87 - Lost communication with ride level control module - Bus signal/message failure - missing a message (2A)
B1A87-68 - Battery disconnection/electronic control unit reset - Algorithm based failure - event information (28)
Parking Brake
U0155-87 - LCD Gauge Communication Lost - Bus signal/message failure - missing a message (A8)
( on 27-07-2024 16:15:59 at 161715 mi )
U0122-87 - Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message (A8)
( on 28-07-2024 13:38:42 at 161765 mi )
C1A00-17 - Control module - General electrical failure - circuit voltage above threshold (A8)
( on 17-07-2024 13:09:52 at 161637 mi )
Transfer Case
P0562-00 - System voltage low (28)
( on 16-12-2021 03:38:48 at 0 mi )
P0563-00 - System voltage high (28)
Tyre Pressure
C1A64-93 - Spare wheel tire pressure sensor and transmitter assembly - Component failure - no operation (68)
Ventilation
B1B74-00 - Front foot-defrost mode stepper actuator (68)
( on 21-07-2024 21:35:24 at 161669 mi )
B1B75-00 - Front foot-face mode stepper actuator (68)
B1B76-00 - Front left air blend stepper actuator (68)
B1B77-00 - Front right air blend stepper actuator (68)
Old Aug 1, 2024 | 01:35 PM
kajtzu's Avatar
Ok. I’d ignore looking for symptoms to all codes for now and instead clear them. Then see what comes back.
Out of that list the most important ones have something to do with voltage. So, you want to at least check the condition of your battery with engine off and with engine running (and alternator charging).
I see the stepper actuator faults in particular are “good” pointers to low battery. They happen on my vehicle when one hasn’t driven with it in a week and the outside temperature is -20 or so.
Ian Mitchell
Dec 16, 2019 05:33 PM
Friday Night Disco
May 26, 2019 08:54 PM
y2motoskier
Apr 28, 2012 02:45 PM
