First post - Lower than "access height" possible?
Old Aug 15, 2012 | 09:15 AM
LeethalG32's Avatar
4wd High
Default First post - Lower than "access height" possible?
Hello, this is my first post and I will be receiving my new-to-me 2005 LR3 Monday. My dilemma is that I cannot fit my LR3 into my garage due to height, even in access mode. A friend of mine just got a RRS and had some device that plugs into the diagnostic port and he claimed he could adjust the suspension height. I am curious, is it possible to get the vehicle lower than access height, or is that truely the lowest the air suspension will go without modifications? I may be able to alter the garage opening to pick up another inch, but if there is an easier way to lower the vehicle, I would prefer that. Thanks for any assitance!
Old Aug 15, 2012 | 12:29 PM
unseenone's Avatar
The short answer is no. At access height the vehicle is on the rubber bump stops it cannot go any lower. That must be a really low garage door. I would say that modifying the door, or potentially lowering the opening at ground level would be the option.
Old Aug 15, 2012 | 02:38 PM
LeethalG32's Avatar
4wd High
Thanks for the response. That's a shame if that's the case. The door is about 5'11", but to add complexity, the vehicle does not go straight into it, instead it goes in at a downward angle, which adds to the overall clearance needed.
Old Aug 15, 2012 | 08:31 PM
bbyer's Avatar
Default On the stops is possible as well as slightly above.
I am not so certain that access is as low as one can get the 3 without being on the stops.
Also if on the stops is low enough, then the link below will do that for you and bring you back up, all via a rotary **** inside the cabin.
The kit was developed by a guy in Australia, (the seller), for the purpose of keeping the 3 up above off road and keeping it there regardless of speed or lack of speed - like a creek crossing when down can be bad.
Over time, he has improved the kit to offer lower and stays there as well but that was not the original intension. I suggest you send him an email off his site; give him the height of your garage door in the email as well as model year, engine etc re your LR3 as there have been some software changes over the years.
His kits connect into the air suspension computer and have a few years of testing behind them now so for the most part, the bugs have been worked out. Price delivered is under six hundred US per the web site.
Llams PTY LTD
Old Aug 17, 2012 | 08:23 PM
unseenone's Avatar
Well, thanks for the jinx.... Car has 1/4" clearance on bump stops with new roof rack fitted. To close for comfort for everyday use... bummer. I guess the rack will stay off except when needed. Very nice rack though, rugged and high quality. (Baja through Lucky8). It looks like the mounts could be made 1" lower which would solve the problem.
Old Aug 18, 2012 | 06:05 AM
threalassmikeg's Avatar
wow.. nice find bbyer
gtokid
Feb 20, 2020 07:20 PM
abqrb2000
Feb 8, 2014 07:25 PM
0304Disco
Oct 15, 2012 05:16 PM
userdmx
Mar 12, 2008 11:52 PM
