Front bumper lights
Old Mar 30, 2018 | 12:10 PM
mnjaws's Avatar
Default Front bumper lights
Who has front bumper lights on their LR3? What have you used to mount them? What lights are you running? What did you do for a switch mount/location?
I would really like to get an ARB bumper with lights and a winch, but the cash just is not there right now. However I do have a need for additional lighting. I have looked at the LR kit VUU500110 but the instructions are a bit weak. Is there sufficient depth for Hella or ARB lighting? Can you only use the LR lighting kit?
Thanks for any help!
Old Mar 30, 2018 | 12:59 PM
DavC's Avatar
Its a car with a 12v battery, you can use whatever you want. You just use whatever wires, relay, switch, lamps, mounts desired.
The LR kit is meant to be plug and play for a dealer to install and look clean. It adds a factory switch on the dash for auxiliary lights. What do you mean by depth?
Old Mar 30, 2018 | 02:09 PM
mnjaws's Avatar
I was referring to the depth of the light housing.
I might have been born at night, but it wasn't last night. I can do without the sarcastic 12V/car comments. If this is not a place where enthusiasts can talk freely about designs and ideas, then I will find another forum.
Old Mar 30, 2018 | 02:48 PM
DavC's Avatar
The kit you reference is the mounting kit. No housings, do you mean plinth? If you are referring to the complete driving lamps kit it is XQB500080. This includes the spot lamps, wiring, switch hardware, etc.
If the depth question refers to how close you can get to the grill face while using the VUU500110 as a base for the other lights, and you mean plinth instead of "housing" it would maybe fit the ARB intensity or say a Hella 1000. If depth is too shallow to use the plinth exactly, a steel plate that relocates the light forward would be fine also. It's just a couple steel tube/plates that bolt to the steel bumper under the plastic one.
Be offended all you want, there is good info here. Another helpful place is D3.co.uk, specific to the discovery 3.
Old Mar 30, 2018 | 02:55 PM
mnjaws's Avatar
I am not offended. It just seems to me that comments like that do little to move the conversation in a positive direction.
Old Mar 30, 2018 | 05:26 PM
clarkritchie's Avatar
This inexpensive curved 30" light bar produces good light, IMO. About $100 on Amazon.
Old Mar 31, 2018 | 11:14 PM
mnjaws's Avatar
I like that look. Do you have a part number or brand/model?
Old Mar 31, 2018 | 11:18 PM
There are a bunch on Amazon. I picked the Auxbeam 32"
here here
Note that you have buy the switch separately, for about $15. I put the switch in the small plastic bit to the left of the traction mode dial. I don't love the location of the switch, but it seemed to be the least invasive place to put a switch without cutting into a larger piece of plastic, etc.
The light is great, I use it all the time.
stroker
Oct 2, 2016 08:40 AM
Drillbit
Aug 17, 2015 12:32 PM
LRD2&ME
Nov 23, 2011 09:44 PM
Jupiter Rover
Jan 26, 2009 05:29 PM
pmccomas
Dec 3, 2008 07:45 PM
