Front Upper Control Arm Replacement
Jeff
I believe using a breather at wrench extender will change the ft lbs of 127 to a much higher setting am I correct with this train of thought?? Ugg
Jeff[/QUOTE]
Jeff[/QUOTE]
ok finished replacement of 2005 LR3 upper control arms ,sway bar links and rotors and pads all on front.
perserverance is the word. If you want to do the job correctly locked in bushings at normal ride height about 18-1/2 inches. Using boxend ofset wrenches and socket 1/2 drive and 2 extensions and 1/2 torx ratchet wrench I was able to get into the correct position to torx the bolt. Driver side harder but got it done
test drive tomorrow
thanks forum members for valued assistance.
demelvin
Jul 30, 2008 10:24 AM
samsly
Jan 27, 2006 12:14 PM
