Front Upper Control Arm Replacement
Old Nov 2, 2023 | 08:07 AM
Rufflyer's Avatar
Default They make the tool you need
Originally Posted by Viking1
Any advice on torx upper control arm main bolts??? No room for socket and torx wrench??
what type of torx tool was used to make this happen??
thanks
For getting a torque setting with a wrench try this
Wrench adapter Wrench adapter
I only show this as an example there are other cheaper and more expensive tools out there, just letting you know they make what you need.
Jeff
Old Nov 2, 2023 | 08:43 AM
Viking1's Avatar
Default Does the extender change the torx ft lb setting??
I believe using a breather at wrench extender will change the ft lbs of 127 to a much higher setting am I correct with this train of thought?? Ugg
Jeff[/QUOTE]
Old Nov 2, 2023 | 08:17 PM
Viking1's Avatar
Default Upper control arms successfully replaced!
Jeff
[/QUOTE]
ok finished replacement of 2005 LR3 upper control arms ,sway bar links and rotors and pads all on front.
perserverance is the word. If you want to do the job correctly locked in bushings at normal ride height about 18-1/2 inches. Using boxend ofset wrenches and socket 1/2 drive and 2 extensions and 1/2 torx ratchet wrench I was able to get into the correct position to torx the bolt. Driver side harder but got it done
test drive tomorrow
thanks forum members for valued assistance.
moorebl
Oct 3, 2014 09:59 AM
comleader
Mar 14, 2014 03:59 PM
Disco Mike
May 4, 2011 07:08 PM
demelvin
Jul 30, 2008 10:24 AM
samsly
Jan 27, 2006 12:14 PM
