Frozen navi touch-screen?
Old Apr 5, 2007 | 07:10 PM
Max_A6's Avatar
Default Frozen navi touch-screen?
I had to pick up my LR3 from the airport garage this morning @ 35F (in VA!), and navi screen wasn't responding to any touching <insert joke here> for a while. Given we can't bypass the Acceptance screen, it would've been quite annoying if I didn't know the route. Has anybody experienced the same?
Old Apr 9, 2007 | 02:48 PM
Jantiz's Avatar
Default RE: Frozen navi touch-screen?
No problems with mine. I do have to ask. Where you wearing gloves? The sensitivity setting on the LR3 screen does seem to be a lot lower than other Nav systems I've worked with.
Old Apr 9, 2007 | 07:27 PM
Max_A6's Avatar
Nope, barehand.
Old Apr 14, 2007 | 03:38 AM
wardolb's Avatar
there is an update for the nav system...but do this disconnect both negative and positive battery terminals, take a set of jumper wires and connect each end to the negative and positive cables let it sit for about 3-5 minutes its called a hard reset. that should work for a while but you need the software update
gilakinlr4
LR4
May 2, 2020 07:18 PM
Zooropa
Jun 28, 2011 07:24 PM
NEWYORKRANGE
Mar 26, 2011 10:57 AM
ChargedRover
Aug 14, 2009 12:27 AM
