Gas Tank Cap Loose or Missing
Old Dec 17, 2007 | 05:56 AM
cocca's Avatar
Default Gas Tank Cap Loose or Missing
1,400 miles on an '07 LR3. The check engine light is on (steady, unblinking). The message displayed is that the Gas Tank Cap is Loose of Missing.
I checked the cap. On, off. Off, on. It's fine.
Nevertheless, the light is still on and the display still insists that there's a gas cap issue.
I know it's under warranty, etc., but is this "one of those things" that has happened or that there's a TSB our there . . . . ?????? Anyone? Anything? Bueller . . . . Bueller . . . .. . [sm=helpout.gif]
Old Dec 17, 2007 | 09:07 AM
Default RE: Gas Tank Cap Loose or Missing
Just run it by your dealer and have them do a quicl vapor leak test.
Old Jan 16, 2009 | 05:29 PM
carlitonsky's Avatar
Did this resolve this isusse?
Old Jan 17, 2009 | 05:58 PM
Jantiz's Avatar
Well, it will certainly point at the problem. Either there IS a vapor leak on the system or the sensor has gone bad. The test will show which. And to answer the original post, this is the first time I have heard of this happening.
Old Jan 17, 2009 | 06:12 PM
cocca's Avatar
actually, it resolved and it never happened again. my guess is that the cap WAS, in fact, loose. the same thing happens to my other car when the cap is loose . . . . .
23k trouble-freemiles and chugging along ..............
Old Jan 22, 2009 | 12:50 AM
and how did you resolve this? couse i took my lr3 to the dealer and they told me the check engine ligth and the gas cap loose or missing is couse by low octanol gas, that i need to empty the tank and then fill it up with high octane gas... Anyways i did that and they put the computer on the car to deleted the error, and when they turn the car on , the ligth came againg...
WHAT SHOULD I DO???
Old Jan 22, 2009 | 01:05 AM
couse didnt you see that the gas tank was loose? u had to buy a new one? or what did you do to resolve this? thanks
Old Jan 26, 2009 | 08:40 PM
PLEASE REPLY
buick215
Apr 26, 2012 10:38 AM
robot808
Nov 18, 2009 11:10 PM
carlitonsky
Jan 29, 2009 09:53 PM
riden686
May 20, 2008 07:48 AM
mge_1
Aug 17, 2006 11:14 PM
