HDC fault after alingment
Old May 22, 2022 | 07:51 PM
toofaroffroad's Avatar
Default HDC fault after alingment
Possibly two things going on here. Took the truck in yesterday for new tires and an alignment. Jumped in to drive it home and HDC fault system unavailable pops up. Get home plug my GAP tool and and i'm not finding any related faults. What should I be looking for?
Now part 2. I did the AB coil conversion about 3 weeks ago. It's actually been great and working perfectly. But now I'm getting the little exclamation mark under the gas gauge and also the triangle fault lower left.
Is there anything that could of happened while doing alignment?
I can currently switch to low range but none of my traction control options are available.
Again, all of this worked perfectly before going into the shop.
Thanks for any help.
Old May 22, 2022 | 08:31 PM
DakotaTravler's Avatar
Inspect/replace brake switch and lamps. With GAP tool, align the steering angle sensor back to zero on center.
Old May 22, 2022 | 09:22 PM
houm_wa's Avatar
The random HDC fault that didn't store sounds like a tired battery to me.
Old May 23, 2022 | 01:06 AM
Guess I should have been more thorough. Battery and alternator are new.
I'll try the steering alignment tomorrow. Thanks.
Old May 23, 2022 | 07:58 AM
tracyc's Avatar
The steering wheel also has to be absolutely centered when the wheels are straight ahead. If they aren't that will throw faults. And yes a steering angle calibration is likely needed too. I've needed one after some alignments with my LR3s.
Old May 23, 2022 | 11:56 AM
DakotaTravler life saver, thank you. Just to close this one up, after having an alingment done I HAD to plug my GAP tool in and do a steering calibration. It's now done and the truck is all good. HDC faults are gone.
Again, this is a blaring reason to buy a GAP tool or something similar if you own an LR3!!!!!
Thanks forum!
houm_wa
Dec 3, 2022 09:24 AM
Jeffrey Changedbygod Ogletree
May 20, 2021 02:06 AM
Tonko007
May 6, 2018 03:01 AM
houm_wa
Jun 25, 2016 10:03 PM
