Heated seats
Heated seats
Hello, 2005 LR3
None of my heated seats work.
They light up when you press the button, fuses are good but no heat front or rear. I have checked the relay fuse as well.
my GAP tool is giving me this code:
B1A73-18 and B1A74-18 (General Electric failure, current below threshold) I’m guessing it’s something other that a damaged heating element since they are all down. Bought this truck 6 months ago and they didn’t work when I bought it. Slowly going through all my issues.
Thanks up front for any help. This forum is a lifesaver.
If your battery really is at 12.0V when all vehicle systems are actually shut down then you've got a battery and/or charging problem at least.
Back to the seat heaters discussion. My drivers seat does not work, the passenger and rear do work. I’m getting the same code. In my case I’d assume I have a broken wire some place specific to the drivers seat. I could possibly replace the seat and hope that fixes the problem. That’s kinda what I’m thinking is wrong with yours. maybe the previous owner replaced seats…. Or someone unplugged the heaters on the seats for some Mickey Mouse fix. Or serious water damage to the wire loom.
relatively easy to find. There’s a plug junction on the front of the seat. The seat is super easy to remove too. Takes about five minutes to remove. There’s more plugs under the seat that can be hard to reach if you don’t have tiny hands. I’ve pulled my seat, checked all the plugs. I think I have a bad wire somewhere.
