Hello, is the 4.0 v6 really that bad when it comes to engine failures?
I just bought a 4.0 v6 lr3 very well taken care of 130,000 miles for 3500, my question is, are the 4.0 v6 really that bad, when it comes to engine failures, how likely are the timing chaing to go?
The LR3 4.0L V6 is essentially the same as the Ford engine found in the Ford Explorer and numerous other vehicles. Do a little research on the Explorer engine and you'll get an idea of reliability. The timing chain guides are made of plastic. They will fail at some point. If the engine rattles during start up and shutting down you're on your way to needing them replaced. If it rattles all the time... stop driving it before you have a major issue. The engine is an interference engine... so when the guides/chains go the valves smack the pistons. Not a ideal situation.
Most issues with timing chains stem from long oil change intervals.
If you read up on Ford 4.0L V6, Ford 5.4L 3V V8, the Land Rover/Jaguar 5.0L V8 —they are all pretty much done in by the hydraulic tensioners leaking down, which causes wear on the chain guides and eventual failure. The tensioner is flawed in all of them, but failure comes from long oil change intervals. If the previous owner kept up with oil changes at a 5-6000, even 7500 mile, interval on synthetic it is probably fine. If there is no startup rattle, then you are good.
By now all these cars, even low mileage ones, are old enough to drive themselves. Don’t expect them to be trouble free, but keep up with the maintenance and enjoy it.
