HELP! 2006 LR3 leaking like a siv
Had the Land Rover since February and it did not leak after sitting outside through most of the winter. Drove it to Austin Texas in mid April through the worst rain storm I have ever been in and did not leak a drop.
We had heavy rain last night and when I opened the front doors, the McNeil mats were full of water on both sides and I am still sponging water from the carpet on the drivers side.
What gives? Where do these things generally leak? At the top of the A pillar? The trim covering the A pillars seems suspect to me. Where else should I look? Is this something that's going to cost me thousands to fix?
It has almost 100k on it. I love the vehicle, but it's getting just too expensive.
HELP!
HELP!
I assume you have a sunroof?
I have to clean sunroof drains on a regular basis on these. The drains will either get clogged with debris, or algae will "glue" the ends of the elbows shut. If you open the sunroof and pour water into the trough around the sunroof, it should drain very fast. If it seems to back up, you need the clean the drains. I usually have to remove the elbows, clean them out and blow through the drain tubes.
HELP!
HELP!
DISCO3.CO.UK - View topic - No more water ingress/passenger side...possibly
Thanks mx468. Did you install the kit from LR on your A pillars that was issued under the technical bulletin? $15 and change from the dealer. Lowest cost part they have, I'm sure.
If you installed the kit, can you post how to do it? Pics would be awesome if you have them.
I ordered the kit today. Won't be in until late this week, so won't get to it until the Memorial weekend, and there is rain in the forecast for the first half of the week. Funny thing is that it has rained since the deluge on Friday, and no additional leaking as far as I can tell. Would the drains have been clogged and all the water flushed them out...of course not before dumping a bunch of it into the interior!
Thanks for your help.
Generally the A-pillar leak is not that much water, as the holes are pretty small, and unless submerged, will not flow that much.
I would be looking at the sunroof drains with it being both sides. They fail in two ways, either draining well, just into the vehicle not out of it, or not draining enough, or at all.
If they are not draining enough, with a heavy enough rain, you can easily overflow the drip tray, which will cause water to come down on both sides. The cowl, where as it will leak the worst, really won't get water on the drivers side of the vehicle, unless it fills the entire heater box.
