Help with 2008 LR3 height sensor supply code/others
Greetings, I’ve got a 2008 LR3 with 177k. New front bags and compressor from the dealer a couple months ago. Scanner is an iCARsoft 3.0, hoping for some direction on working out some codes that popped up last week. Suspension light came on while making a hard right turn while raising to off-road height.
1. C1A68-1C: Front left height sensor supply (permanent)
2. C127-14: compressor circuit (intermittent)
3. C1A03-1C: Front left height sensor (intermittent)
Pulled the 20 amp suspension fuse for 2 days, everything stayed inflated as it should. Pulled the 5 amp suspension fuse, it lowered down over night. Inflates when turned on and drives fine, no excessive compressor running. This is definitely more complicated than my D1! I didn’t turn up any results with a search so if you’ve got a thread to send me to or info I’d appreciate it.
OdinsbeardD1 (09-20-2022)
Genuine LR parts are $125-200 per sensor. Obviously ridiculous $ for such a simple part, but they do *tend* to last 100-200k miles. So, not Toyota reliable, but pretty good for Land Rover parts.
More recognized off brands like "OEM" (such a deceptive brand name but it is what it is, see below) are $75-125. Auto parts store ones are typically Dorman and ~ $125 - not a good brand but they sometimes have lifetime warranties. Cheapest no-names on Amzn and Ebay are maybe $20-40.
I've had an "OEM" branded one bought from Lucky8 fail after less than a year. (They did send me a replacement after it failed - it had a 1 year warranty I think). I was honestly pissed off at the false advertising when I received it, since these "OEM" brand parts are not what most of us mean by oem, meaning it's the same part made by the same manufacturer as the genuine part, just without the vehicle brand attached to it, i.e. a Denso branded oxygen sensor that is identical to the Land Rover branded (Denso) oxygen sensor except for the Land Rover brand on the packaging. That was my first and last time being tricked by the "OEM" brand. Same goes for the "Genuine", "OE", "OE Supplier" etc brands.
I've also had an el cheapo ($35 delivered next day from Amazon) last for years. These can be just as good as genuine ones, but it's a crapshoot. But the more expensive off brands can be crapshoots too So I'd go with either genuine Land Rover *or* the cheaper branded ones from somewhere like Rockauto personally.
You could buy 4+ sets of cheap ones for the price of genuine anyway, and they are a 5 minute job to switch out. Not including the suspension calibration of course!
Not sure how helpful that was lol, but that's what's available.
tracyc (09-21-2022)
I believe the front left sensor part number is LR020155? If so, they can be had for cheap from LR direct. And unlike some sellers, when they say OEM they truly mean it. I have purchased many "OEM" parts form LR Direct and they are indeed OEM. In some instances the LR logo has been simply scratched off! There is shipping, but with current exchange rates the pricing from LR Direct is great. For example, I need a new lower steering shaft. New OEM is only $180 shipped from them.
