Help with third row seatbelt replacement?
Old Jan 5, 2021 | 09:25 AM
wheeler's Avatar
Default Help with third row seatbelt replacement?
My puppy chewed one of the seatbelts on the driver’s side of the third row seat of my 2007 LR3 HSE. I purchased a replacement seatbelt on eBay. Regarding the seatbelt attachment points, I’m not seeing how to access the nut that secures a bolt passing through the floor. At the other end, the seatbelt retracts through a slot in the back upper trim panel. That trim piece warns that there is an airbag behind it. I read a post in this forum that it's easy to break the clips when removing that trim piece. Any tips for how to remove the trim without damaging it or affecting the airbag? I searched YouTube and didn't find any helpful videos. Does anyone have any photos or diagrams to explain the moving parts? Or can you walk me through the steps to gain access and which special tools are needed- I presume a Torx. Thanks!
Old May 19, 2024 | 02:55 PM
johnsonmc2000's Avatar
Did you ever find anything or have any tips on this? I have removed my third tow and am wanting to remove the seat belts.
Old May 19, 2024 | 03:02 PM
wheeler's Avatar
My LR3 is long gone out of my possession but we did replace the seat belt. We had no problem regarding the airbag and removing trim near the floor was straightforward. If you are simply trying to remove seatbelts, perhaps you could cut the belts out and leave the attachment as a tie down.
Old May 20, 2024 | 09:00 AM
Thanks. I did find that the black side trim pulled with some force would move enough at the top to release from the top trim clips.
mark j
Jan 3, 2017 02:48 AM
Matt927
Jul 25, 2016 07:16 AM
film842
Sep 20, 2014 01:37 PM
MONEYMIKE
Oct 20, 2013 08:30 AM
MONEYMIKE
Oct 19, 2013 05:01 PM
