HID conversion kits
Old Jul 10, 2009 | 09:56 PM
snowplower's Avatar
Smile HID conversion kits
i have a simple question i just bought a hid conversion kit for my LR3 however it does not seem as easy to install as it is shows on the box, does anyone know of where i can download a step by step process
Thanks
Old Jul 10, 2009 | 11:35 PM
Street Wolf's Avatar
Well, it's extremely easy.
Plug ballast into existing vehicle wire harness.
Mount ballast
Put the light bulb in the headlamp
Plug the light into the ballast
...and your done.
Old Jul 12, 2009 | 12:56 PM
Rippin'AV's Avatar
I've always complained about the stock LR3 lights. I'm curious what you think about the HID upgrade??? Let us know how it goes...
Old Jul 12, 2009 | 09:25 PM
snowplower's Avatar
i tried installing them but they will not light, i troubled shoot a little and it works if i connect them directly to the battery, it seems to be a DRL relay problem. Does anyone know where this is located (DRL Relay) apparantely i need to disactivate this in order to make them work, or purchase a add on called a relay bypass????
Old Jul 15, 2009 | 05:12 PM
stormtrooper's Avatar
the correct way to set up a full conversion is to retrofit a projector lens, as xenon bulbs emit a much stronger light, and tends to blind on coming traffic, this is more important in LR3's as they sit higher up and the light without a proper cut off will light up cars like a stadium...in California you can be ticketed for this...here is some stuff you can read about the retro fit...
http://store.theretrofitsource.com/
they sell parts and do have recommendations for retrofitters, a warning though it can get on the pricey side quickly to do it the correct way...
Old Jul 15, 2009 | 10:45 PM
trynian's Avatar
That is why I just swapped out the entire halogen units for a factory set of xenons found on ebay. Easy plug and play and less then $500 if you have the patience.
Old Jul 16, 2009 | 12:07 PM
yep this would be the best way to do it for sure. when I was hunting for my LR3 I looked for the lighting package as it can get pricey and up there or it could take some time to find the reight situation...btw, any one know the bulb applications of the fogs and main headlight(xenon)
LRDII2000
Sep 25, 2012 06:27 AM
thomas22
May 12, 2009 01:42 PM
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
Remo@70dollarhidscom
Member Group And Special Buys
Jan 16, 2009 10:57 AM
steve125
Motorcars LTD
Jul 13, 2007 07:00 PM
