How to program a new LR3 replacement remote
Old Jan 19, 2007 | 06:16 PM
accessories4less's Avatar
Default How to program a new LR3 replacement remote
We just purchased a new replacement remote for our 06' LR3 and needed info on how to program the remote? The dealer wants $50 for this, which I find a little steep for 2-5 minutes worth of work. Any help would be greatly apprecaited!
Old May 11, 2007 | 12:59 PM
jodilynne516's Avatar
8th Gear
Default RE: How to program a new LR3 replacement remote
Does anyone know about this? Also, is there anywhere other than the dealer to pick up a key & remote? The dealer wants $250 for the key, plus the cost to program. I saw one uncut on ebay and was wondering if that one would work. Thanks!
Old May 12, 2007 | 12:30 AM
bribake's Avatar
I've wondered about that too..I only have 1 remote and have wanted to get an extra but don't want to pay $250 either. If you end up doing it let me know how it works!
Old May 12, 2007 | 09:15 AM
If your remote is like most of the newer remotes from Rover, they have to be programed with a test book and you can only have 2 remotes set up for the same vehicle at one time. By the way, the dealer had to pay over $30,000 for the test book, thaat is why it is so expensive to have them use it.
Mike
Old May 5, 2016 | 05:51 AM
LR3LEBANON's Avatar
does anyone know how to program a brand new key from the dealer on 06 lr3
Old May 5, 2016 | 11:53 PM
abran's Avatar
Yes. You need the right computer.
If you are near so cal I can do it. I also have remotes I can sell.
Old May 7, 2016 | 12:31 AM
ljdiscovery's Avatar
What do you charge for your remotes, programmed. Thanks. Phil
Old May 7, 2016 | 08:20 AM
abran's Avatar
$200.
It's a reflashed used remote, new rechargeable battery soldered to the board, and new remote case.
Your rover has to be physically present for me to code it.
Old Dec 14, 2016 | 06:28 PM
Steve Trifunovic's Avatar
How do I get in touch with you?
Old Dec 15, 2016 | 07:47 AM
Abran programmed some remotes fit me for our lr3 and our Range Rover sport. He did a great job. You can also get a gap diagnostic gap too IID. You can use it to program your remotes as well as a ton of other things for truck. Phil
