jumping suspension compressor
Old Aug 18, 2020 | 12:46 AM
ljdiscovery's Avatar
Default jumping suspension compressor
can you jump the air suspension compressor if you don't have a key to the truck . i am trying to get it to raise to normal height. i am wondering if you can use a battery to attach directly to the compressor leads. ideas? thanks Phil
Old Aug 18, 2020 | 11:21 PM
driftology's Avatar
probably not. the system is pretty complicated. you would need to power the pump and also trigger all of the valves. it also needs the height sensors active to know when to stop. if one thing isn't responding, it will error out and not do anything
Old Aug 19, 2020 | 11:42 AM
thank you, you are probably right, I hadn't thought about the valve blocks, maybe with the relay out? Phil
Old Aug 20, 2020 | 01:10 PM
driftology's Avatar
Without power, i think all of the valves are closed. remember there are valves at the tank too.
Old Aug 20, 2020 | 10:23 PM
Globetrotter448's Avatar
Where are the keys??
Old Aug 21, 2020 | 01:35 AM
stolen out of the truck. backlog on new remotes at dealer no eta. trying to figure out what can be done until new key is sourced.
viewsonic
Nov 16, 2022 04:58 PM
ljdiscovery
Jun 11, 2020 10:42 AM
gtokid
Feb 20, 2020 07:20 PM
Burfyworld
Apr 1, 2014 10:23 AM
alti
Oct 25, 2013 10:45 AM
