LR3 4.0L V6 engine oil sump removal
Old Jul 3, 2024 | 12:29 AM
nivekau's Avatar
Default LR3 4.0L V6 engine oil sump removal
Hi all,
Has anyone removed the engine oil sump pan on the 4.0L V6 engine in a Discovery 3?
I've removed all the bolts and the pan won't budge, I'm a bit nervous about trying to lever the pan off because it doesn't look particularly robust and I don't want to bend it for obvious reasons.
I note that the gasket has 2 or 3 rubber lugs which protrude through holes in the oil pan - do these need to be cut off to get the sump pan off?
Keen to hear from anyone who done this job!
Old Jul 7, 2024 | 06:56 PM
nivekau's Avatar
I got it off. I managed to get a flat blade screwdriver between the block and the oil pan at the corner where it was leaking and it came off really easily once the gasket seal was broken.
cvhyatt
Jan 14, 2022 07:55 PM
rhyslegge
Apr 14, 2020 03:56 PM
SailorTom
Mar 9, 2015 07:58 PM
golgafrinch
Jan 5, 2015 10:33 PM
chargersfan
Aug 25, 2007 12:22 PM
