LR3 4.4 Overheating Issue
Old Aug 28, 2024 | 08:44 PM
rikkd's Avatar
Originally Posted by Justjaycie
Maybe I am just paranoid, still working on my LR3 cooling system. Flushed the front heater core and about to do the rear. The issue I am having is that it overheats after maybe 15 minutes of driving and coolant boils out of the reservoir. There is no smoke, no milky oil and no bubbles in the coolant. I have performed a combustion leak test and the fluid stayed blue. Is there any other symptom to diagnose a bad head gasket or is there just air in the system? No rear heat at the moment but I am not sure if its air or if its clogged, I am about to try and flush it tho. Maybe a clogged radiator? Not sure how to diagnose that.
Have you tested the thermostat? Overheating quickly is a sign of a thermostat, and has similar symptoms of a clogged radiator. See if the radiator gets hot when it overheats or if its still cool/lukewarm. You could use a laser thermometer to see where there's hot or cold coolant and locate hot spots. If its hot it means its getting coolant cycled through the motor, if its closer to ambient than the motor temp it means its not getting coolant cycled through the motor.
I don't remember if the heater core is before or after the thermostat but that could be a hint.
Old Aug 29, 2024 | 09:02 AM
lenzda's Avatar
I’m not an expert on mixed coolant types, defer to others.
as for the vacuum fill, Indrew -25psi($) on the systems. Let it sit like that for a minute Tony ensure it would hold a vacuum. Once confirmed I filled the system with coolant.
The rubber hoses did get very flat, nothing to worry about. The coolant stopped flowing once it filled the system (still about -3psi of vacuum when coolant stopped flowing). I squeezed the hoses to help the process along. Added about 3/4” of coolant to the reservoir tank after driving to get it to temp.
Old Aug 29, 2024 | 10:17 AM
Justjaycie's Avatar
I could pull it out and boil it in a pot to see if it’s working properly. I have noticed that the thermostat housing gurgles and I can hear air rushing towards it when I turn the vehicle off. So I’m guess it’s a bleeding/flow problem. Since I have a new radiator and thermostat assembly. I’m gonna change all that, flush the cores and vacuum fill. Might as well tackle it all in one go. I guess I just needed confirmation that the engine was ok before I went ahead and threw money at new parts.
Old Aug 29, 2024 | 06:19 PM
rikkd's Avatar
If your replacing it anyway, it may be a good idea to test the new and the old one just to confirm if it was the culprit. Takes less than 15 minutes to do and you will know exactly what caused it. Plus if its a working thermostat you can keep it as a spare for yourself or another rover.
Old Sep 24, 2024 | 12:50 PM
Justjaycie's Avatar
Ok it ended up being a water pump, so I replaced the water pump, radiator, thermostat housing and did a vacuum fill and all seems to be running smoothly. No overheating, just a code for bank 1 and bank 2 too lean. Would that be a MAF sensor?
Old Sep 24, 2024 | 04:29 PM
DakotaTravler's Avatar
Lean banks are usually caused by a vacuum leak. This can be from bad intake gaskets, valve cover gaskets, etc. One common issue though is intake duct plastics cracking.
Old Sep 25, 2024 | 04:13 PM
rikkd's Avatar
Glad you were able to fix it!
nevillusa
Dec 19, 2023 06:00 AM
Waldoch
May 27, 2018 05:16 AM
kmyer01
Nov 1, 2011 06:40 PM
Flyin2jz
Mar 2, 2010 12:54 PM
winnie
Feb 10, 2008 11:59 AM
