LR3 Air Suspension gets a 2 1/2" lift
Old Feb 1, 2009 | 02:53 AM
  #21
cuda's Avatar
Default RE: LR3 Air Suspension gets a 2 1/2" lift
ok , i want the 2.5 lift sensor arms , who wants to sell me some ? or who knows the best place to buy stock arms ?
Old Feb 1, 2009 | 02:25 PM
  #22
Jantiz's Avatar
ORIGINAL: cuda
There is new development on that subject on another forum you really want to see. Follow thelink below. Youcan also read the maon part of the post I pasted below as ell.
http://lrrforums.com/showthread.php?t=10639
Finally! Adjustable Height Sensor Joining Rods
After a years worth of R&D, the Rods look to be ready to enter the market. I hope to be able to deliver sometime in February. The kit will consist of (2) Rear Rods and (2) Front Rods with instructions / disclaimers. This may not be the exact final look as I am still fine tuning a couple of aspects. Imagine being able to simply adjust the Rod length while still being attached with sensors in place! Product consists of Lightweight Nylon Composite Rod Housing with High Temperature Silicone Ends with a operating range of -60*-500* attached to 6061-T6 High Strength Aluminum Rod Connector with RH / LH thread spec. Target price range will be $269.00 per set (4) shipped to your door. Fits '05-09 LR3 (D3) with a Range Rover option to follow. How about some feedback...
Old Feb 1, 2009 | 05:05 PM
  #23
drzjoint's Avatar
If you want I can make you a set just give me a pm
Old Feb 17, 2009 | 12:19 AM
  #24
Blakt Out's Avatar
4th Gear
I can't find one place to see a pic of the LR3 lifted with these. What size tire are you getting under it?
Old Feb 17, 2009 | 06:27 AM
  #25
drzjoint's Avatar
A few guys are running a 275-65-18 but I beleve they are getting a little rubbing in norm mode. alot of people like the lift so you can drive faster on the trail and you can flip to super ext mode without getting hung up. It is more of a semi stock mod. If you want a set let me know.
Old Feb 17, 2009 | 06:40 AM
  #26
drzjoint's Avatar
these were with the cell phone in off road mode if I remember correctly
Attached Thumbnails  LR3 Air Suspension gets a 2 1/2" lift-lr3-1.jpg    LR3 Air Suspension gets a 2 1/2" lift-lr3-2.jpg    LR3 Air Suspension gets a 2 1/2" lift-lr3-3.jpg    LR3 Air Suspension gets a 2 1/2" lift-lr3-4.jpg
Old Feb 17, 2009 | 07:04 AM
  #27
drzjoint's Avatar
Here is a comparison in off road mode
Attached Thumbnails  LR3 Air Suspension gets a 2 1/2" lift-lr3-5.jpg
Old Mar 9, 2009 | 01:32 PM
  #28
drzjoint's Avatar
The rods are on sale 175 shipped to your door just drop me a line
Old Mar 17, 2009 | 07:54 AM
  #29
silvy423's Avatar
do you think I can get away with a 285/55/20 running this lift?
Old Mar 17, 2009 | 11:30 AM
  #30
drzjoint's Avatar
You should be ok that is 32.4" guys are running 32" 285-65-18 and 275-65-18 tires stock with some mild rubbing so I would say with the modified rods you should be fine.
