Lr3 with a bunch of codes.
Old Dec 14, 2020 | 07:55 PM
asenduy's Avatar
4th Gear
Default Lr3 with a bunch of codes.
Recently purchased 2006 Land Rover LR3 SE unseen from auction with a bunch of codes. I would appreciate any input on what you guys think these codes may be. I do know that it has a possible trans. issue. I would like to know what things can pull this many codes/what should I tackle first?
The codes are:
  • PZ579
  • U2023
  • U0100
  • U0300
  • P081C
  • U0102
  • U0155
  • PZ603
  • U0126
  • U0122
  • P0562
  • P0713
  • P0900
  • P0915
  • P1811
  • P1807
  • U0101
  • U0138
  • P0561
  • P0702
  • P186D
  • U1A03
Thanks for all you help!
Old Dec 14, 2020 | 08:19 PM
Low voltage can do that. Clear the codes run it and see what come back.
If the battery is low charge it up first. Check voltage while running as well
Old Dec 14, 2020 | 08:47 PM
asenduy's Avatar
4th Gear
Low voltage was not an issue. Also battery was replaced.
Old Dec 14, 2020 | 09:46 PM
P0562 is a low voltage condition code.
Have you cleared the codes since you replaced the battery? Have you checked voltage when running?
Old Dec 14, 2020 | 10:02 PM
asenduy's Avatar
4th Gear
Yes and voltage was normal.
Old Dec 15, 2020 | 07:15 AM
Ok so no voltage issues.
Than you have multiple trans codes and a locking diff code.
How does the transmission behave when driven. Have you checked the fluid level and quality (burnt smell off color etc)?
Old Dec 20, 2020 | 02:23 AM
Globetrotter448's Avatar
What is the battery voltage when:
1. everything shut down, ign off.
2. When idling.
3. Have you done a total system reset.
Old Dec 20, 2020 | 02:57 AM
asenduy's Avatar
4th Gear
I will get those figures and get back to you. Also how do I do a full system reset? Clear the codes and pull the battery?
Old Dec 20, 2020 | 01:13 PM
pagoda's Avatar
Clear the codes. Switch off the vehicle. Let it go to sleep. Disconnect the battery leads and short them with a jumper cable or something similar and leave them in that state for about 30 mins. It's referred to as a 'hard reset'.
Old Dec 25, 2020 | 11:09 PM
canamrotax's Avatar
4wd High
My old RRS had a similar issue when the battery cover was not in place and a well meaning car detailer sprayed high pressure water into the electrics on the right side of the firewall. After disconnecting the large plugs , spraying with contact cleaner, and waiting to reconnect overnight (see hard reset) it all played nice again.
TyTyBinks
Sep 2, 2020 10:45 AM
jafir
Nov 11, 2013 01:11 PM
buick56
May 15, 2013 06:11 PM
chad420
Jan 13, 2011 01:37 PM
JEFIII
Sep 8, 2010 09:12 PM
